× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX120 VPN Connection issues using Pulse Secure
CMBautista
Follower
Internet speed is pretty good. But when I try to connect to the VPN for work (Pulse Secure) the speed slow up to 10%.
I have the firmware V 1.0.1.122  and I already have the NAT Filtering in Open and Disable SIP ALG.
Do you know what other thing I can try?
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 2
Christian_R
NETGEAR Employee Retired
Re: RAX120 VPN Connection issues using Pulse Secure
Hi CMBautista,
I would suggest contacting our support team to look into this further.
https://www.netgear.com/support/default.aspx
Christian
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 917 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
