× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX120 bridged slow 5Ghz wifi speed
blackart
ISP plan: 1000M
Router Firmware Version V1.2.1.22
RAX120 work as bridge mode as the following:
Main router(asus)     <-----wifi 5g------>  RAX120   <-----cat8 cable------> PC
5ghz: PC  got  75M (download),  700M (upload)
2.4ghz: PC  got  130M  (download)
If my PC use a typical usb wifi adpater instead of rax120 to connect main router, it got  250 Mbps. Other mobile phone also got 250Mbps.
I guess there are something in rax120 restirct the 5ghz connection speed.
Please help fix the issue. Thank you.
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 3
Accepted Solutions
blackart
Re: RAX120 bridged slow 5Ghz wifi speed
thx for your reply.
My problem is fixed. I turned off Main router's 5ghz  AX function.
My PC now get 500Mb.
Message 3 of 3
All Replies
Guru
What speed do you get if you connect the rax120 (in access point mode) to the Asus and test its speeds?
curious if there's an issue with the 5ghz or possible with it being in bridge mode.
Message 2 of 3
blackart
thx for your reply.
Message 3 of 3
Discussion stats
  • 2 replies
  • 1228 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
