- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX120 constantly dropping WiFi until reset
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX120 constantly dropping WiFi until reset
- Mark as New
- Bookmark
- Subscribe
- Permalink
Has anyone reached out to Netgear yet? Is this a firmware issue, or something else? I even changed out my cable modem (was over 3 years old) with no luck, still having to reset periodically.
- Mark as New
- Bookmark
- Subscribe
- Permalink
For what it's worth, I think I've found the cause of this on my router. I've had my RAX120 a few months now and haven't had a problem. Like most other posts on the subject my issues started happening early March. I saw another post about firefox switching the default protocol to DNS-over-HTTPS (https://www.computerworld.com/article/3529424/firefox-starts-switching-on-dns-over-https-to-encrypt-...) and tested it using the routers Default DNS server settings. Sure enough, soon after having a couple pages open in Firefox all DNS was broken and thus the 'internets' were unavailable.
I left the setting enabled in Firefox (and stopped using it for now). I switched my default to Chromium Edge and the network has been solid for 24+ hours vs. the 1-2 hours I was getting.
Currently my firmware is rolled back to 108 and it's been solid. After another 24 hours I'll go back to 114 with 118 hotfix.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I should also note that my DNS servers are set to cloudflare right now. 1.1.1.1, 1.0.0.1
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did notice I was on Firmware version 114 and I added the hotfix 118. I have not tried rolling back yet. My DNS is 75.75.75.75, 75.75.76.76. I do not use firefox, just chrome. I'll roll back my firmware and see if that helps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Interesting article. I wasn't using Firefox so I didn't start reading this right away, however, I read it and found this quote.
"Google has been testing this "same provider, auto upgrade" approach since 2019, but has not yet spun it to the entire Chrome user base. According to this document, Google plans to do so with Chrome 81, currently slated to release March 17."
On the same day I started having issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Oh interesting, I thought Google wasn't going to do that.
Also I forgot to mention that for me, TOR browser never stopped working for me.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Same here...2 - 3 days ago family started complaining that their wireless XBox, iPad and iPhone would drop Internet yet my wired dock contiuned to work fine. Cycling the RAX120 a couple times a day now.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Interesting so far today. I am still running the latest firmware and hotfix 118. I set my DNS to 1.1.1.1,1.0.0.1 and had no reset issues all day until about 45 min ago when my router completely reset itself back to factory (first time the router did this). I will keep it as default for now and report back.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Perhaps the internet is under a bit of pressure at the moment with many working from home.
ive noticed some disconnects, I can see the logs show multiple disconnects and reconnects before the connection goes stale.
as my issue is only recent and reading about companies like Netflix lowering data I would say my issues relate to my isp and the pressure on their network.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
On the internet setup section issue it's set right and not on dial up.
also as the internet is suffering at the moment would you think maybe the issues might be more to do with isp's.
in case though have you reset your router, setup fresh after using rear pin hole method.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Tried different DNS settings and reverted back to frimware from November and the drops continued. Wired and wireless Microsoft laptops and most IoT's Internet continued to work fine while every Xbox (wired or wireless), iPhone and iPad would only go a few hours before the RAX120 need cycled. 7 hours ago switched back to an old, non-NetGear router and have not had any issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Only 1 semi-reboot (wasn’t the same as prior, Guest network remained up) in the last 48 hours. We’ll see, hopefully whatever network gremlins were plaguing my system have since moved on... 🙂
Hopefully there will be a firmware update soon to address these issues. Good luck everyone!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hey all,
I've started looking at some of the global DNS issues that seem to be related to shift in network burden related to people working from home. It definitely doesn't explain spontaneous resets, but it does make a little sense for the network related issues.
https://downdetector.com/status/cloudflare/map/
I'm hoping this all means as ISP's shift to adjust for more people working from home this will start to iron out over the next week or 2.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@ricachica82 wrote:
I’ve owned this router for two weeks, and it has done this same thing to me, then factory reset on me twice when I unplugged it, forcing me to completely set up my router again from the beginning. I have gig fiber service with a static IP address. For as much as I spent on this thing, I’d hoped for more stability.
there is an update here, download and install.
https://www.netgear.com/support/product/RAX120.aspx#download
Perform a factory reset after updating, use the rear pin hole method and setup as new. Do not use a saved config.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
