- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- Next »
RAX120 constantly dropping WiFi until reset
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX120 constantly dropping WiFi until reset
Just turned mine into a $500 access point. Ugh. Not happy!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Details are so important to help people understand your issues.
What steps have you taken to solve what ever issue you have?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Bought a different router. Problem solved.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Why did not try to seek help?
- Mark as New
- Bookmark
- Subscribe
- Permalink
All good. It works great as an access point. No more internet issues. Im a happy camper.
- Mark as New
- Bookmark
- Subscribe
- Permalink
But what issues did you have, are you happy that you have a very expensive AP?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It keeps dropping internet. On both ports. Internet port and multi gig. My internet is all better, so yeah I'm happy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please perform a factory reset using the rear pin method, set up as new and do not use a saved config profile.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Newfiedrool wrote:Please perform a factory reset using the rear pin method, set up as new and do not use a saved config profile.
Thank you!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you factory reset it after it updated its firmware? 1.2.0.16 really needs that reset, if not try it, but if you have done that (it only takes a few minutes) its probably hardware, so not so much a troublesome router just bad luck if it is. Mine has been fine apart from a buggy QoS in the current firmware is bugged and is also basic, no dynamic QoS on this unit.
I hope you can factory reset the router and get it working or just exchange it. Also be aware a newer Revision 2 unit is coming out soon that will do up stream MU-MiIMO and UL OFDMA as well as TWT and BSS, the original unit canot do UL OFDMA or Upload MU-MIMO, so if you have not got a revison 2 (It will say on the box and it does 160Mhz not 80+80) then maybe wait for new stock.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I had the same problem. Its the router for sure. I turned off the wifi and bought some access points. I havent had a problem since. Been up and running for 4 months with no connectivity issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The low speed thru stressed out is what I need assist identifying. Per your idea, I attempted three one-of-a-kind devices (laptops) wired to the router however the speeds nonetheless are low. I also attempted exclusive cables however no development.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have been dealing with Netgear tech support for the last few days and nothing has been fixed, after many diffrent attempts, from multiple individuals and now waiting to hear back from them as 2 days has passed and were suppose to reach out to me already to send another router as this one is more than likely defective as everything they have tried does not work. Factory reset has been done multiple times, changed settings, changed modems 3 times with 2 diffrent types, was on latest update .88 and had me go back to .78 because supposedly after all else has been done, last yech said there are some known issues with the most current update being .88.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX70 constantly dropping WiFi until reset
- Mark as New
- Bookmark
- Subscribe
- Permalink
My R7800 does NOT do it. It has to be this router. Grrrr.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- « Previous
- Next »
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
