- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX120 does not keep WAP2~WPA3 Personal settings
- Mark as New
- Bookmark
- Subscribe
- Permalink
When I try to set WPA to anything other than WPA3 the setting always goes back to WPA3. I have an 8 year old Logitech Universal Remote that uses WiFi and I believe the WPA setting may be causing issues with connectivity. Any suggestions?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for the question about browser vs. App. I was using Safari thru iPadOS so I tried the Nighthawk app and the WPA2+WPA3 setting now looks like it is “sticking”. That also seems to have fixed the Logitech connectivity issue.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX120 does not keep WAP2~WPA3 Personal settings
Are you doing it through the browser?
through the app?
Have you tried a different pc and/or browser?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad you got it working!
might mark it solved so others aren't still trying to fix your issue 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Done…. Thanks again…
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
