× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
RAX120 drop internet, comes back after reboot
danielshaw007
Hi all. I have a RAX120 v1 router, its been fine for over 2 years. Lately, my internet seems to die. Wifi connected, without internet access. I reboot the ONT and same issue persists, then I reboot the router and internet access is restored.
I believe this is a known issue and there is some beta firmware that fixes this? If so how do I have a go at this firmware?
Thanks
Message 1 of 29
Guru
Re: RAX120 drop internet, comes back after reboot
Beta FW was for v2 120's.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What devices do you all have connected?
What are you doing thru the router when this happens?
Does the router feel extra warm or hot when this happens?
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Armor, Smart Parental Controls or Circle, Traffic Meter.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-rout...
Message 2 of 29
TrumpKing
I'm also RAX120v1 user, I can confirm both RAX120v1 and v2 have reboot issue on 1.2.8.40 firmware, but different symptoms.
Are you using multi-giga (5G/2.5G) port of RAX120 as LAN or WAN? Avoiding using multigiga port may stop it rebooting.
If you need to use the multi-giga port, the beta firmware can reduce the reboot times to once every few weeks. It can recover itself automatically after reboot, you don't need to plug and unplug power cable.
I wrote some ways to resolve the issue here. https://community.netgear.com/t5/Nighthawk-with-WiFi-6-AX-and/RAX-120-V1-Firmware-Version-1-28-40-co...
AX6000 WiFi Router (RAX120)
Message 3 of 29
danielshaw007
I'm using the regular WAN not multi gig.
It went down again about 30 mins ago, rebooted my TP Link MC220L media converter and internet was still down, rebooted the RAX120 and internet came back up.
I never had this issue with my previous 100mbit connection, now I'm on 900/900mbit it seems to be taxing the router a lot more?
Frustrating, I think i will replace the router with the newer RAXE500 as I have a few devices now that can use the 6ghz band.
Message 4 of 29
danielshaw007
What Firmware version is currently loaded? 1.2.8.40
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? I ditched my ISP Adtran router / ONT combi unit for a TP Link MC220L media converter
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.  - Yes cat6
What devices do you all have connected?  TVs, phones, tablets, smart bulbs , doorbell 19 devices total
What are you doing thru the router when this happens?  sometimes literally surfing the net
Does the router feel extra warm or hot when this happens?  no warmer than usual, fan not on
Any Wifi Neighbors near by? If so, how many? ive scanned and changed channels. also the LAN connected clients lose internet access when it stops working.
Armor, Smart Parental Controls or Circle, Traffic Meter. - done no change in issue
Funny thing is I've had this router about 3 years, previously it was attached to a 4g modem as there was no fibre where I l live, now its connected to a 900/900 service. I dont think I ever rebooted the router intentionally before. All seems to have started when I got the new faster service, almost like its taxing the router too much.
Note, i have not done a factory reset since the last FW update. I will try this and report back.
Message 5 of 29
Guru
Message 6 of 29
danielshaw007
Pin push factory reset seems to have improved things. No need to have power cycled the router in the last 7 days and I have found some extra speed too which is a bonus!
Will see how it goes due course. Thanks for the tips
Message 7 of 29
Guru
So you just FR and setup from scratch. No FW update?
Message 8 of 29
danielshaw007
Pretty much. Router was on latest public fw, I think I once updated it via the app and never factory reset it since then. Perhaps that is all it needed.
Message 9 of 29
Guru
Kewl. Good to hear.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Message 10 of 29
danielshaw007
Hi again. Been looking at the log on the router today as noticed occasional connected with no Internet messages on my phone.
Every 10 to 30 or so mins there is a line saying "Internet Connected, then my IP and date and time"
Does this indicate the wan keeps dropping and reconnecting ?
Thanks
Message 11 of 29
microchip8
Master
No. That's a message from a self-test the router does. It probes the connection every X minutes or hours and logs a message.
Message 12 of 29
Guru
What is the first 3 characters of the routers serial number?
Thanks
Message 13 of 29
danielshaw007
67U
Message 14 of 29
Guru
Message 15 of 29
danielshaw007
Thanks, I'm guessing another factory reset after flashing ?
Also is there a full changelog for this fw ?
Thanks
Message 16 of 29
That's usually necessary only if you have post update issues.
Netgear does not provide detailed logs. Most updates bill themselves as "security updates".
For obvious reasons these don't get listed. You don't want people to know about those things because they open the doors to attacking people who have old firmware.
Message 17 of 29
danielshaw007
Makes sense.
Noticed the router dropped all wireless clients before, as the log had loads of dhcp requests from my devices.
Flashed the beta fw now and done a cold start so I'll see how things go.
Thanks
Message 18 of 29
Guru
Keep us posted on how it goes. Normally I would recommend a full on reset and setup from scratch. See how it goes. Also, Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
Message 19 of 29
danielshaw007
Will do.
What's the significance of changing the dhcp range if you don't mind me asking ?
Thanks
Message 20 of 29
Guru
Less management and processing that the router has to do. specially if you really don't have 100+ devices. 🙄
Also sets up flexibility for using static IP addressed devices on either side of this pool if needed. I've been using this kind of configuration for many years.
Message 21 of 29
danielshaw007
Still having issues.
Is the RAXE500 router stable ? Might upgrade.
Thanks
Message 22 of 29
Guru
What issues are you having?
Yes.
What region are you located?
Message 23 of 29
danielshaw007
Random lack of connectivity.
Now when this happens I can't even connext to router with netgear app from an external network. I reboot the router and it works again.
UK
Message 24 of 29
Guru
And that's with the beta RAXv1 RC FW applied and factory reset?
What channels are you using currently?
What are the Basic and Advanced Wireless settings currently configured for?
Message 25 of 29
Top Contributors
Discussion stats
  • 28 replies
  • 3013 views
  • 0 kudos
  • 5 in conversation
Announcements
Orbi 770 Series
