× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
RAX120 drop internet, comes back after reboot
danielshaw007
Re: RAX120 drop internet, comes back after reboot
Yes, yes
Wifi channels 13 and 44.
Not at home now to check settings, but it's all default. Factory reset a few weeks ago and all I did was change the SSID and set the WAN connection
Thanks
Message 26 of 29
Guru
Can you try channel 1 and 40 if there not busy?
Also set 40Mhz only on 2.4Ghz.
I would enable beamforming and MIMO features under Advanced/Wireless settings as well.
What devices do you have all connected to the router?
Does both wireless and wired connection see issues or just wifi?
Message 27 of 29
danielshaw007
I don't have any wired clients at the moment.
Checked with a WiFi analyser app just now. My 5ghz network had a hidden network that is quite strong overlapping on chan 44. So presume changing to 40 will mitigate this? I have captured a pic of the 2.4 range near me. My network is SKYNET. Quite busy on that also near me. So changing that to 1 looks like it may help ?
Thanks
Message 28 of 29
Guru
Yes, lets go to 1 and 40.
Might also try lowering the power from 100% to 50% and see how it runs as well. Helps to lessen the wifi interferences from other wifi nieghbors. Power is either under basic wireless settings or advanced/wireless settings.
Message 29 of 29
Top Contributors
Discussion stats
  • 28 replies
  • 2939 views
  • 0 kudos
  • 5 in conversation
Announcements
Orbi 770 Series
