×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
RAX120 problems on 2.5GHz
siliconglen
Tutor
Most of my devices use 5Ghz however a couple of legacy devices use 2.5Ghz. The 2.5Ghz don't have the hardware to connect at 5Ghz
Router was upgraded through the app to V1.2.1.22 firmware recently and have noticed since then the 2.5Ghz devices are failing to connect. Issue might be related to the firmware upgrade, impossible to be 100% sure on this as I rarely use 2.5Ghz but for a few devices it's a must have and they need an update.
The connection issue is universal across all of the devices (including new devices which would prefer to be on 5Ghz)
The error reported is "incorrect password" which plainly isn't the case as it wasn't changed. Nonetheless I rebooted the router, changed the password to something else, let the router reboot, changed the password back again, let it reboot again, forgot the network on all the devices then tried to reconnect - ie I forced the router to accept a password update then put it back to what it was.
Still getting either "unable to connect" or "incorrect password" errors.
Fed up with this.
Due to the poor support after 90 days for what appears to be a Netgear hardware or firmware issue, will be sending router back unless anyone has any other suggestions?
Using WPA-2 Personal [AES] WPA3 Personal
Some actual diagnostics would be really useful rather than guess and hope.
For the moment I'm getting by using a mobile hotspot on 2.5Ghz which allows the devices to connect
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 10
Accepted Solutions
siliconglen
Tutor
Re: RAX120 problems on 2.5GHz
This is no longer working. Have the  latest firmware, set the 2.5Ghz band to no password and still couldn't get a connection.
Then set the password and the invalid password errors reappeared. I must have a reliable 2.5Ghz as I have devices which only use this band. Also, I don't appreciate my time being wasted and in the unlikely event I ever work in an office again, I'm not having my family hindered by unreliable internet while I'm out the house.
The netgear support is poor and offers nothing except a robot reponse and "call this number" after 90 days, offering no free options for anyone with a speech issues or who doesn't want to take up time during the valuable working day when I am facing customers.
Therefore and on the basis of multiple independent reviews I'm going for the ASUS RT-AX86U
%age of 1,2,3 star reviews on Amazon for this product Vs the RAX120:  8% Vs 23%
1 star reviews 3% Vs 12%
Rated Excellent by PC Mag: https://uk.pcmag.com/wireless-routers/129217/asus-rt-ax86u-ax5700-router
Rated best for the money by CNET: https://www.cnet.com/home/internet/asus-rt-ax86u-wi-fi-6-router-review/
Favourite Standalone Router by Tom's guide: https://www.tomsguide.com/uk/reviews/asus-rt-ax86u
Impressive by Techradar https://www.techradar.com/uk/reviews/asus-rt-ax86u
Highly rated by Dong https://dongknows.com/asus-rt-ax86u-ax5700-gaming-router-review/
I need a relatively up to date router that is secure and reliable. Netgear isn't reliable.
Message 10 of 10
All Replies
siliconglen
Tutor
Additional info:
Have checked for channel conflicts - none
Have checked signal strength : -45dBm
Broadcasting on channel 13.
changed password to one longer than the original incase there was an issue with overwriting the Nvram. Still "invalid password"
Is there any decent windows or android diagnostic tools which can show me what's going on at the packet level and give me a detailed log complete with the return status code?
Message 2 of 10
siliconglen
Tutor
I turned off the password, restarted the router and forgot the network. The error is now "Couldn't authenticate connection".
Message 3 of 10
Razor512
Prodigy
Keep in mind that some devices to not support mixed WPA2 and WPA3 modes, where if they have compatiblilty issues, they will endlessly try to connect or simply find whatever password you enter as wrong.
Message 4 of 10
Chichizola
Star
In other word they don't work as adverticed. @DITCHNETGEAR
Message 5 of 10
thehypnootoad
Luminary
With my 2.4 ghz devices I personally reserve the ip address as they just struggle to connect ... but since this update my google hubs keep dropping connection and my s20plus 5g keeps giving me authentication error messages till I make a static ip on the phone.
Message 6 of 10
siliconglen
Tutor
Printer only connects on 2.5Ghz and is giving me an error "MAC address may be filtered" error code E-6. I don't have MAC filtering on.
Message 7 of 10
james1795
Make sure to disable 20/40 coexistence. Also under wireless just do WPA2 and see if that works for you. I had to do this to mine so my wireless printer would connect on the 2.4 band.
Message 8 of 10
mariosuper47
Initiate
Firmware update V1.2.1.22 caused this yesterday on my router.   I didn't realize that the update had occured until nothing else I tried worked.   Everything had been working fine until yesterday.   But then 2.4 Ghz wifi was dead even though the lights on the router were flashing as if the band was active.   All my home smart connections were disconnected and I couldn't switch them to 5 GHz
Finally I checked firmware and found the firmware version above had automatically updated.   I then unchecked the box for automatic update of firmware and rolled back to the next oldest version of firmware.
Viola!  Everything works again.    I have had this sort of thing happen previously with other Netgear routers but, up until now, the RAX120 had been rock solid.
Message 9 of 10
siliconglen
Tutor
Message 10 of 10
Top Contributors
Discussion stats
  • 9 replies
  • 2329 views
  • 3 kudos
  • 6 in conversation
Announcements
Orbi WiFi 6E
