× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX120 ss Through port forwarding PPTP not working.
Williaml99
This worked on my old router but not on my new one. Forwarding port 1723 and 47 TCP and UDP to the target system. Works direct to modem and works on old router. What am I missing?
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 6
Williaml99
Re: RAX120 ss Through port forwarding PPTP not working.
Forgot to include.
Firmware Version V1.0.0.84
Message 2 of 6
msedhom
I'm having the same issues with port forwarding - none are working.
Also, can't access router remotely even when Remote Mangement is enabled.
Message 3 of 6
Christian_R
NETGEAR Employee Retired
Hello Williaml99 & msedhom,
After you've done the port forwarding, can you confirm that the ports are open using a third part port checker site (ping.eu). Looking forward to your updates!
~Christian
Message 4 of 6
schumaku
Guru
@msedhom wrote:
I'm having the same issues with port forwarding - none are working. Also, can't access router remotely even when Remote Mangement is enabled.
Your ISP does any kind of carrier grade NAT? Compare the "what is my IP address" with the IP address the router does show assigned on the Internet/WAN port - if not the same, figure.
Message 5 of 6
msedhom
This. It was a different IP. Stupid me!
All working now.
Message 6 of 6
Top Contributors
Discussion stats
  • 5 replies
  • 2398 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
