- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX120V1 Intermittently power cycling?
- Mark as New
- Bookmark
- Subscribe
- Permalink
My RAX120 that I purchased around a month ago has suddenly started to "Turn off" leaving only the power LED on (blinking). During this item, all internet service is interrupted and after about a 1-minute wait the router resolves itself and resumes function.
I've been informed that there may be a BETA Firmware that resolves this issue. Any help would be appreciated!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX120V2 Intermittently power cycling?
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (GS116v2)
Desktop: AMD Ryzen 9 5900X - Server: Intel Core i7-7700K - NAS: Intel Pentium G4400, 20 TB
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yeah, that was the first thing I opted to do. I've been trying to figure this issue out for the past few days and I was informed of a BETA Firmware that may resolve the issue that I can access from this forum via Reddit just a little while ago
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the first 3 characters of the routers serial number please.
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Gateway Mode | Wifi Router and RBK853 | Switches NG GS105/8, GS308v3, GS110MX and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50v2, XR450/500/700/1000, EX7500/EX7700
- Mark as New
- Bookmark
- Subscribe
- Permalink
1: I rolled back and used V1.2.3.28 in hopes of that resolving the issue, it did not. Currently using 1.2.8.40
2: Unfortunately I am not sure what "Mfr" means, the closest thing I see on the modem is "mfg" which states 06/21. The modem is provided by Spectrum and is Model Number "ET2251"
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Galliard
I have sent you a PM.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the first 3 characters of the routers serial number please. Just verifying that you have a v2 to be sure.
Mfr = Manufacturer.
The PM is in regards to a beta if yours is a v2. Should fix the reboots your seeing.
3: Im using this cable in the 6 ft size.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX120V1 Intermittently power cycling?
I just finished installing the Beta Firmware Im not 100% sure what triggers the intermittent outages so ill just have to wait for a few hours/days before determining its fixed.
First 3 of SN: 571
The router information portion of the Router Settings also states "Hardware Version RAX120v2" for what its worth.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be aware that you don't have a V2, yours is a v1. V1s did not experience this issue. Only v2s did.
FW may report this incorrectly in the UI as the FW is directed to v2s.
I would not presume that the beta should cause any issues though the problem could still be seen or may cause other issues to be falsely seen with out doing more digging into why your v1 is seeing this issue using non beta FW. Anything could be possible.
Lets let the beta run for 3 days and come back and let us know your results.
