× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX120V2 cannot access router after Factory Reset
KoinFlipper
Tutor
RAX120V2 router
Did factory reset and now cannot access router to setup. When I go to www.routerlogin.net it redirects to 192.168.1.1/BRS_index.htm
Says Internet detected. Cannot get past Admin Account Settings. The admin username and New password are grayed out and cannot change factory default. I select security questions and type in answers but the NEXT button stays grayed out. Did Netgear brick my Nighthawk RAX120v2 router? How do finish setting up my router?
Message 1 of 2
Guru
Re: RAX120V2 cannot access router after Factory Reset
Try the reset 1 more time. Push and hold reset for 7-15 seconds.
Then reattempt the setup.
Usually when the next is grayed out, you didn't meet the minimum requirements for something.
Make sure the password you setup has at least 10 characters
1 special character
1 upper case
1 lower case
1 number.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 2
Discussion stats
  • 1 reply
  • 326 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
