Orbi WiFi 7 RBE973
Reply
RAX120v2 LAN & WiFi Disconnects
xrsenal
Hello I own the RAX120V2.
I factory resets after performing a manual firmware upgrade multiple times.
Wether it’s every hour or every 2-3 hours,
ALL wifi disconnects (wifi band disappears) and all LAN devices disconnect EXCEPT for the 1 device I had under static reservation.
Can someone please give me a firmware fix or do I have to manually assign IPS to everything?
Model: RAX120|Nighthawk AX12 12-Stream WiFi Router
Message 1 of 3
Guru
Re: RAX120v2 LAN & WiFi Disconnects
What devices do you have connected?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Are there any LED inidications seen when this happens on the router?
Message 2 of 3
xrsenal
I’m not answering all these details.
This is clearly an issue with the firmware. I’ve seen tons of posts about this.
Every other router works fine.
XR1000,R2, all asus routers….
What is the firmware fix for this
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 748 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
