Orbi WiFi 7 RBE973
Reply
RAX120v2 Lan Ports Stuck at 100 mbps in AP Mode
My model is Nighthawk AX12/RAX120v2.
Since switching my router to AP mode, devices connected to my LAN ports stay at 100 mbps.
I have Cat 5E cables and tried a different cable that isn't from the same batch I bought.
Is this by design?
Thanks!
FALSE ALARM IGNORE.
Running a speedtest from my Playstation 5 made the port speed change from 100 mbps to 1000 mbps.
I'm guessing the same'll happen if I can figure out a way to force the same on my LG C1.
Message 1 of 3
Accepted Solutions
Re: RAX120v2 Lan Ports Stuck at 100 mbps in AP Mode
Another update...
LC C2's port speed is 100 mbps... so it was never the router. Sheesh.
Message 2 of 3
All Replies
Another update...
Message 2 of 3
Guru
Glad you got it figured out!
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 660 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
