- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX120v2 Wifi signal keeps dropping
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, my wifi signal keeps dropping almost every day and requires constant rebooting. The problem is not with the modem.
Please help.
Thanks,
Phil
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX120v2 Wifi signal keeps dropping
Just FYI, the Nighthawk app says I am updated with the latest firmware.
Provider: Spectrum
No wifi nearby
Devices: 5 computers, Eufy 2C security system -2 base stations, two iPhones, one printer, LG TV. Apple TV.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the first 3 characters of the routers serial number?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I don't see a manufacturer name or model number. What I do see is this:
ES2251
DOCSIS 3.1 eMTA
Made in Philippines
SD10
There is also a CM MAC number and a MTA MAC number
Does that help?
- Mark as New
- Bookmark
- Subscribe
- Permalink
That is not a reliable guide. The app seems to miss some updates, especially if you are several versions behind.
The only way to really check is to look at the firmware version ans to compare that with the versions available on the support pages for your device.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
That page will also have any software, firmware and drivers for your device, if they exist.
As to your modem, Google isn't definitive. Probably just a modem, but does it have extra LAN ports on the back? Does it do wifi?
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the first 3 characters of the RAX120 router serial number?
- Mark as New
- Bookmark
- Subscribe
- Permalink
//What is the first 3 characters of the RAX120 router serial number?//
The first three characters are: 6JY
The modem has only one ethernet port and two voice ports. I don't know if it does wifi. I picked it up new last week from the provider (Spectrum).
The firmware is up to date according to the product support pages.
Thank you so much for helping me!
Phil
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sounds like modem only device.
- Mark as New
- Bookmark
- Subscribe
- Permalink
//Sounds like modem only device.//
Is that significant to my router problems? Just curious.
Phil
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please load this FW up:
Factory reset and setup from scratch after its loaded. It fixes randsom reboot issues seen by users with the 120v2 unit.
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-rout...
https://kb.netgear.com/25722/How-do-I-reserve-an-IP-address-on-my-NETGEAR-router
Phil
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please lost this FW up:
Factory reset and setup from scratch after its loaded. It fixes randsom reboot issues seen by users with the 120v2 unit.//
Sorry, but I'm confused. I don't have a reboot issue, I have a wifi signal dropping issue. The router gives me no indication that the signal has dropped. My devices will show no wifi until I reboot the router manually.
I am also confused by your words: "please lost this FW up" . Do you mean, Please look this FW up?
If so, will I need to do a factory reset? And if so, do I upload the FW before or after the reset?
Thank you,
Phil
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please load up this version of FW. Factory reset after the FW is loaded and the router is back to ready:
https://kb.netgear.com/24233/How-do-I-erase-the-configuration-settings-on-my-Nighthawk-router
- Mark as New
- Bookmark
- Subscribe
- Permalink
OK, I have uploaded the new FW, then saved settings, did a factory reset, then reloaded settings, so I assume the configuration is back to what it was.
So, now we see if that solved my issues? Or is there anything else I need to do?
Thanks again,
Phil
- Mark as New
- Bookmark
- Subscribe
- Permalink
Saving the config and introducing it back into the same may result in see the problem. IF you do again, reset and setup from scratch, this time do not load the saved config from back up..
What channel configurations are currently set on the router? Basic and advanced sections please.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@PhilBates wrote:
... then reloaded settings...
Bad idea.
To clarify the other, possibly confusing, reply you received, reloading the settings can bring back the problem that you had in the first place.
Stick with the settings as they are, but, if you see the same problem, reset the device and see happens.
If you still have the problem, then you can reload the settings on the basis that you haven't reloaded the problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Don't believe it. Visit the support pages and compare your version with the latest.
Support | NETGEAR
It might also help if you told people what the modem is in front of this router, if there is one. The make and model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
Do the router's logs offer any clues?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Any progress on this?
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
