× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX15 Won't Assign Static IP (R6400 Would)
PapaBear47
RAX15, current firmware (V1.0.1.58_2.0.31)
On my old R6400 I had a static IP assigned to my mobile phone (to make it easier to use it as an FTP server when moving files around). I tried to do the same on the RAX15, but I got the following:
      400 Bad Request
      This server does not support the operation requested by your client.
I set the DHCP ending IP address to 192.168.1.199, and since I successfully assigned 192.168.1.200 to my network printer I doubt there's a collission problem with 192.168.1.201 or any of the others I've tried; still, the router won't allow it.
Any insights or advice appreciated. Let me know if there's any more information I need to supply.
Message 1 of 4
Christian_R
NETGEAR Employee Retired
Re: RAX15 Won't Assign Static IP (R6400 Would)
Hello PapaBear47,
I would suggest contacting our support team to look into this further.
https://www.netgear.com/support/default.aspx
Christian
Message 2 of 4
PapaBear47
Christian, thanks for your response. As it happens, about the time you posted I solved the problem ("solved" = "something I threw at the wall finally stuck"). Apparently, even with WiFi turned off the phone had enough connection to the router that the address couldn't be changed; when I powered the phone off and added its MAC address manually, the address assignment worked. I don't remember having to do this with the R6400, but that was some time ago
Don't know whether this merits addition to a knowledge base or FAQ, but in my case it's resolved.
Message 3 of 4
Christian_R
Hi PapaBear47,
Thanks for getting back with an update! Happy to hear you got it resolved.
Best regards,
Christian
Message 4 of 4
Discussion stats
  • 3 replies
  • 835 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
