× Attn: Nighthawk Pro Gaming members, we have recently released firmware to address a critical security vulnerability. For more information click here. .
Orbi WiFi 7 RBE973
Reply
RAX20 LAN ports are capped at 100mbs
R-Kasten
Hello, my router (info pasted below) does not reliably give me full speed on the LAN ports specifically.  I have 900+mb/s to the modem, and if I plug the ethernet cable (cat6) directly into the modem I get my full plan download speed of 500mb/s.  If I then route the ethernet cable from modem > router, and plug my computer into the router I'll get 500mb/s once, and then 100mb/s afterwards.  If I power cycle the router, I'll get 500mb/s again but then it reverts to 100mb/s.  I've tried all 4 ports and the behavior is the same.
Hardware VersionRAX20
Firmware VersionV1.0.11.112_2.0.77
GUI Language VersionV1.0.11.112_2.1.46.1
Operation ModeRouter
CPU LoadCPU1: 5.00%  CPU2: 4.44%
CPU3: 4.27%  CPU4: 1.67%
Memory Usage(Used/Total)333MB/497MB
Flash Usage(Used/Total)110.43MB/256.00MB
System Uptime0 days 19:14:39
Message 1 of 8
Accepted Solutions
Guru
Re: RAX20 LAN ports are capped at 100mbs
Be sure the ethernet drivers are up to date as well.
The RAX only supports up to 1Gb connection rates so you might set a manual connection rate on the adapter for 1Gb only.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
Message 8 of 8
All Replies
Guru
What does the speed indicate on the routers web page under Advanced tab/Show Stats button.
Look at the connection rate for the LAN ports that have connected devices here.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Message 2 of 8
R-Kasten
The LAN port shows a speed of 100M
I am using a CAT6 cable, and when using that same cable directly from the modem I get 500mb/s. I have fiber internet from Surf and the modem is a :
UFiber loco m/n UF-LOCO.  Thanks for the quick reply.
Message 3 of 8
Guru
What is the devices connected at LAN2?
Does this happen if you switch to other LAN ports?
Do you have another ethernet supported device to help test with to compare?
Message 4 of 8
R-Kasten
I only use one device on lan, everything else I use wifi for.  The device on LAN2 is my gaming desktop, the same behavior happens on all 4 of the ports. I have a separate desktop that I was fixing for my father, it also gets capped at 100MB with the ethernet cable.
Message 5 of 8
Guru
What is the brand and model # of the PC and brand and model# of the ethernet adapter installed in the PC.
Message 6 of 8
R-Kasten
I rebooted the modem and the router for about the 5th time and now I'm getting full speed.  LAN2 is showing 1000M/FULL now, both desktops are using Realtek Gaming GBe 2.5 chipsets.  I'm all set for now, sorry to waste you time.
Message 7 of 8
Guru
Enjoy. 📡
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 594 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
