×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
RAX20 authentication problem
alpnet17
Initiate
I have Netgear model # RAX20. My cell phone (Android) cannot connect to Netgear WiFi. I get this message: "Authentication Problem" . How can I connect my cell phone to Netgear WiFi?
Message 1 of 8
Accepted Solutions
Guru
Re: RAX20 authentication problem
did you put in the password wrong?
Try deleting the network from your phone and re-connecting it.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 8
All Replies
Guru
Message 2 of 8
siliconglen
Tutor
Didn't work for me.
Changed the password, same error
Made the network open, got "can't connect"
Then went back to password protected and went back to the error
Message 3 of 8
Guru
Is it only 1 device with the issue?
Are you using any special characters in the ssid/password?
Message 4 of 8
alpnet17
Initiate
I tried your solution and it worked fine. Thank you.
Message 5 of 8
siliconglen
Tutor
It's happening on multiple devices.
No characters outside of A-Z, a-z, 0-9
Message 6 of 8
siliconglen
Tutor
No
Tried that several times
Message 7 of 8
Guru
@siliconglen Maybe start your own thread so we can go over your info and not get it confused with the OP
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1338 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 6E
