- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX20: can I set WPA3-SAE+WPA2-PSK mixed?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Other brands can set WPA3-SAE+WPA2-AES mixed mode, so clients that supports WPA3-SAE can use WPA3, while older clients can still use WPA2-AES.
but how to do this with RAX20?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX20: can I set WPA3-SAE+WPA2-PSK mixed?
So you see mixed modes on the routers web pabe under Basic Tab/Wireless settings?
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CAX80 Modem Mode | Wifi Router RBKE963 and RBE973 | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX30/CAX80/CM1100/CM1200/CM2000, Orbi: CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, MK93S, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000,
- Mark as New
- Bookmark
- Subscribe
- Permalink
not with netgear routers, but routers of other brands can do this.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If you need this then you should return the RAX and find something that does.
Good Luck.
