× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
RAX20 dropping connection or extremely slow
jcolinger3
Follower
Spectrum > Cable Modem (Charter/Spectrum) E31T2V1 Docsis 3.1 > RAX20 (V1.0.11.112_2.0.77)
I've had to reset my RAX20 many times. Not sure what is going on. It has been a persistent issue.
Maybe something is getting it into a weird state.  Not happy, and even with a TP-LINK old cable modem/router combo, I never had these issues. Prob shouldn't have "upgraded".
After reset of the RAX20 ONLY, the speeds go back to normal.  But here is a test showing the slow speed.
Message 1 of 2
Guru
Re: RAX20 dropping connection or extremely slow
Are you getting good speeds with a wired PC connected to the ISP modem directly?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
How is basic and advanced wireless settings configured on the router?
Be sure any mobile device MAC Address Randomizers are disabled:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-...
Message 2 of 2
Discussion stats
  • 1 reply
  • 377 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
