Orbi WiFi 7 RBE973
Reply
RAX20
Andreas-Jackson
RAX20
Help required in the control panel of my rax20 wifi router it keeps stating reboot even though i have and updated the software once i have solved this issue i have purchased another rax20 and wish to connect them together wirelessly so i can increase the range of my network
Message 1 of 2
Accepted Solutions
Guru
Re: RAX20
Are you talking about using the 2nd router in access point mode?
Or are you still having issues? If its still issues, a better description of the problem would be advised.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
Message 2 of 2
All Replies
Guru
Re: RAX20
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1366 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
