- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX200 - Ethernet Port - Red light
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
I recently purchased a new router, the RAX200, and I'm extremely happy with its performance.
However, as of last night, the ethernet port keep on showing a red light instead of a steady white light. Is the router going bad?
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX200 - Ethernet Port - Red light
Which ethernet port?
1-5?
Wan port?
If its the 1-5 port, it indicates a 10/100mbps connection and not gigabit.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX200 - Ethernet Port - Red light - follow up
Hi Plemans,
Thank you for your response.
So the ETHERNET port I was referring to is the YELLOW RJ45 port that the router uses to connect to the ISP modem.
Thanks for all your help 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
What ISP modem is it? (model)
Have you checked the cable? I've seen sketchy cables cause issues.
Make sure its a cat 5e or better cable and decent quality
- Mark as New
- Bookmark
- Subscribe
- Permalink
RAX200 - Ethernet Port - Red light - The never ending saga ;)
Hi Plemans,
The Spectrum Modem is a DOCSIS 3.1 cable modem - 3.1 E31N2V1 Hitron.
Also, ethernet cable looks good, decent quality - Cat 7... Been using it for a few months, no problem.
Thanks 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX200 - Ethernet Port - Red light - The never ending saga ;)
you can check the port statistics.
How do I display Internet port statistics on my Nighthawk router? | Answer | NETGEAR Support
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX200 - Ethernet Port - Red light - Checked Port Stats
photos have to be approved by a moderator and can take a while.
You can clikc on "choose file" and manually add them
- Mark as New
- Bookmark
- Subscribe
- Permalink
RAX200 - Ethernet Port - Red light - Checked Port Stats - Photo
oh ok,
lets see if this work. I just chose a jpg file.
Thanks
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX200 - Ethernet Port - Red light - Checked Port Stats - Photo
Are you using wan port aggregation?
Or the 2.5g port as wan?
- Mark as New
- Bookmark
- Subscribe
- Permalink
RAX200 - Ethernet Port - Red light - Update
Hi Plemans,
No, I am not.
Nope.
Thanks.
