× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
RAX200 Firmware
mayo73
Star
RAX200 Firmware
I noticed that the firmware for the RAX200 hasn't been updated in over a year. Is this router on the EOL list ? I checked and it doesn't seem to be . Expensive router with not much support it seems . Thanks
Message 1 of 4
Accepted Solutions
Guru
Re: RAX200 Firmware
Its not EOL but usually firmware updates fix bugs or security issues. Is there a bug you've got with it?
Message 3 of 4
All Replies
Re: RAX200 Firmware
Is this where you looked?
NETGEAR End of Service | NETGEAR
Have you see any security issued, or reports of them, that make you worry about your router?
New routers get more frequent updates because there are bugs that need squishing. With luck we shouldn't need any of these.
After that, updates are usually for security issues, often dealing with "threats" reported on fancy websites but that hardly, if ever, make their presence felt in the real world.
Netgear maintains a list of these things and the kit that might get hit:
NETGEAR Product Security | NETGEAR
Message 2 of 4
Guru
Re: RAX200 Firmware
Message 3 of 4
mayo73
Star
Re: RAX200 Firmware
Thanks for the reply . No issues . Just wanted to know if it was on the EOL list. Working great . Thanks.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1348 views
  • 5 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
