× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
RAX200 Mesh?
StephenMA
RAX200 Mesh?
Is the RAX200 a Mesh system? I have the EAX80 extender, which is a mesh extender, but can't seem to determine if the RAS200 router is mesh (or even if it matters)...?
Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 1 of 7
Accepted Solutions
Guru
Re: RAX200 Mesh?
The SB8200 and the RAx support link aggregation. Are you using it? if so, disable it. its been known to be problematic for boht devices.
Another thing to try is to simplify. Remove the EAX and just run router and modem. If you still have the issue, then directly connect to the modem and run it for a while to see if you still have the issue.
The SB8200 also has modem connections page. you can take a screen of that and it shows the connection back to the ISP
Message 7 of 7
All Replies
Guru
Re: RAX200 Mesh?
The RAX200 isn't a mesh system. The EAX is a mesh extender but paired together they're not a full mesh system. that'd be something like orbi.
Message 2 of 7
StephenMA
Re: RAX200 Mesh?
Will Mesh be better via the Orbi than the RAX200? I keep getting drops with the RAX200 via my current extender system, which bugs me as the RAX 200 is an expensive router and I didn't expect those kinds of problems....
Message 3 of 7
Guru
Re: RAX200 Mesh?
What modem are you using?
are both wireless and wired dropping?
Is it only the devices connected to the extender dropping?
What firmware is on each?
Is it specific devices dropping?
Message 4 of 7
StephenMA
Re: RAX200 Mesh?
SB8200 3.1. I can't tell if its my ISP (Cox) that has the hickup or my router. I think it's Cox because I usually have to reset everything to get it back up and running... Frustrating....
Message 5 of 7
StephenMA
Re: RAX200 Mesh?
When i say have to reset everything, mainly mean rebooting the SB8200....
Message 6 of 7
Guru
Re: RAX200 Mesh?
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 7804 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
