×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
RAX200 Power LED is blinks slowly and continuously
nguyenthuyen
I am using netgear Rax200 router.
I have tried updating the version 1.0.4.120 with the Nighthawk app, but a few times failed. May be Internet singalI. I tried restart again and then it was failed.
Now, Power LED is blinks slowly and continuously, the router firmware is corrupted. This happen while i am firmware update is interrupted, the router detects a problem with the firmware.
I can't login to the router with a PC, it does not have a WiFi signal to login by iPhone.
Pls help me!
Thanks!
Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 1 of 5
antinode
Guru
Re: RAX200 Power LED is blinks slowly and continuously
> [...] Power LED is blinks [...]
   You may be a candidate for the TFTP recovery scheme.  See, for
example:
   https://community.netgear.com/t5/x/x/m-p/1622096#M102004
   I'd forget any Netgear-supplied app, and use a web browser on a
computer with an Ethernet connection to the router.  (Which you'd need
for the TFTP recovery scheme, too.)
> I can't login to the router with a PC, [...]
   For future reference, "can't" is not a useful problem description.
It does not say what you did.  It does not say what happened when you
did it.  As usual, showing actual actions (commands) with their actual
results (error messages, LED indicators, ...) can be more helpful than
vague descriptions or interpretations.
Message 2 of 5
nguyenthuyen
Thanks for suoport,
I tried flash tftp with PC, but it not work, I tried changing the ip address to 192168.1.1 and reflash by tftp, but it still doesn't work
Message 3 of 5
antinode
Guru
> I tried flash tftp with PC, but it not work, [...]
   The TFTP recovery scheme is a multi-step procedure which offers
multiple opportunities for user input, hence user error.  By itself,
saying that you "tried" it doesn't say much.  And "not work" is no
better.  As usual, showing actual actions (commands) with their actual
vague descriptions or interpretations.  Especially when using a
command-line program, copy+paste is your friend.
> [...] I tried changing the ip address to 192168.1.1 [...]
   "tried changing the ip address" of _what_?  The crippled router
should already be at "192.168.1.1".  Your computer should be at a
similar but different address, like, say, "192.168.1.10".  Read the
instructions again, more carefully?
Message 4 of 5
nguyenthuyen
Sorry, if I can't answer you soon, maybe, because I'm not good at English, and because I'm in the sea, 4G signal is poor.
Message 5 of 5
Discussion stats
  • 4 replies
  • 882 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
