Jeston
May 31, 2019Initiate
RAX200/RAX120 feature question
Hey guys. I'm looking at buying either the RAX120 or RAX200 but had a question regarding possible features. First thing I'm looking for us the ability to create a guest network. Is this possible? Second thing I'm looking to do is setup QoS on either a specific connection, or even the guest network as a whole. It seems that these are both possible with the Nighthawk Pro Gaming routers, but I'm looking at these two as I would like 802.11ax connectivity.
Jeston wrote:
First thing I'm looking for us the ability to create a guest network. Is this possible?Yes.
Read the manuals.
If you visit the support pages:
you can feed in the model number and find all the documentation for the hardware.
- JestonInitiate
Thanks for the help. Looks like this router only has very basic QoS and is missing several other features. Shame DumaOS isn't on these. Why would they put such a dated/stripped down firmware on a $400 router? I guess it's time to take a look at Asus' offerings. I've always been a Linksys fan since the WRT54GL so these brands are new to me.
