× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX200 Readyshare Issue
lfryejr
Tutor
I used to be able to access the Readyshare network after configuring two hard drives.  However, now I cannot.  I upgraded to the latest firmware and still cannot.  I tried to a thumbdrive to insure it wasn't the HDDs and had the same issue.
However, I can access the drives via the HTTP link and am able to navigate the HDDs from a web browser.
The lack of connectivity is from multiple devices - Win10 PC, MacBook, etc.
Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 1 of 2
Christian_R
NETGEAR Employee Retired
Re: RAX200 Readyshare Issue
Hi Ifryejr,
May you let me know what firmware version your router is currently on? You may try performing a factory reset and running through the setup assistant again. Let me know if your issue persists.
Christian
Message 2 of 2
Discussion stats
  • 1 reply
  • 597 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
