× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX200-Wifi SLOWING DOWN and dropping
JJ24
Initiate
Wifi 2.4 SLOWING DOWN and disconnecting me at times. 5G doesn't even wanna connect most of the time. I've rest the router so many times and a master resets. Nothing is working even thought it was my internet but no they came out several times and all is good... Everything is up to date just don't know what to do anymore thinking of changing brands idk???😭
Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 1 of 3
Guru
Re: RAX200-Wifi SLOWING DOWN and dropping
1. what actual firmware version are you on?
2. what modem/gateway is it connected to?
3. do wired devices have issues or just wireless?
4. is it both bands for 5ghz or just one of them?
5. are you using smart connect?
Message 2 of 3
JJ24
Initiate
1. Firmware - V1.0.5.132_1.0.69
2. Modem - ARRIS surfboard SB8200
3. No wired are 100% good
 4. Just 1 5g turned off 2nd one
5. No smart connect
Thanks for the reply 😁
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1143 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
