× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX200
sharkuae
Follower
RAX200
Dear support team,
I have two device RAX200 and both of then the lan connection stop working when i try to connect using lan cable and i can access the device using only wireless soultion and sometimes device will not respond for wireless as well.
V1.0.3.106_1.0.58
GUI Language Version
V1.0.3.106_2.1.46.1
Model: RAX200|Nighthawk Tri-band AX12 12-Stream Wi-Fi 6 Router
Message 1 of 2
Christian_R
NETGEAR Employee Retired
Re: RAX200
Hello sharkuae,
If you recently purchased the device I would recommend contacting our support team as newly purchased devices are provided with 90 days of complimentary support. You may open a ticket by registering your device using the link below.
https://www.netgear.com/support/contact.aspx
Christian
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 644 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
