× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
RAX35 - Confused about installation
pilon29
Initiate
Folks
This may be a stupid question and I apologize. I just installed the RAX35 Router and realized it came with a CAT 6 Cable but no phone cable and there is nowhere to plug the line from the wall into the router. Do I need to purchase another piece? I was trying to replace the old Modem/Router that the internet provider gave me. I got it working but right now it goes
From the wall jack tinto the internet plug using a regular phone cord, then I plugged the cat6 cable into the old modem/router (port 1) then into the internet port in the back of the nighthawk. Does this sound right? I was hoping to get rid of the old modem/router.
Thanks in advance for any help.
Message 1 of 3
Guru
Re: RAX35 - Confused about installation
The RAX35 is a router only. it isn't a modem. If you have dsl, you'd need a dsl modem.
If you're prior setup was a dsl modem/router device then you might still need to use that device but place it in modem only/passthrough mode.
Message 2 of 3
pilon29
Initiate
Thank you very much. I found the instructions to set it to modem only.
Message 3 of 3
Discussion stats
  • 2 replies
  • 555 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
