- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX40 Firmware 1.0.3.80 Crash/Bug Log
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX40 Firmware 1.0.3.80 Crash/Bug Log
Today I read an article that the model of the RAX40 router has serious security problems. I hope the developers in the next firmware will take into account all the comments on the work of RAX40
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
For me is RAX40 really unstable. It connect and disconnect all time with LAN, 5Ghz and 2.4Ghz on Firmware 1.0.3.80.
And I have noticed behavior of 5Ghz. I choose a wifi channel, but the router always go back to channel 36 even if this is the worst channel. I belive it crash, becuse I can see channel numbers av changed in Wireless Settings (5GHz)
- Mark as New
- Bookmark
- Subscribe
- Permalink
When will the firmware update come out with the removal of comments?
- Mark as New
- Bookmark
- Subscribe
- Permalink
FYI, like a lot of us, I had serious stability problems.
No issues for 2 days and then wifi breaks for all the home devices. Ethernet was stable.
It happened 3 times in the week.
Checked and modified my Wifi settings stable for a couple of weeks :
Disabling Smart Connect and having the same SSID for 2.4 and 5ghz
Disabling Mix mode WPA2/WPA3 and using only WPA2 AES
Just FYI.
Hope we will have soon a good firmware....
- Mark as New
- Bookmark
- Subscribe
- Permalink
So is your router still stable or has the issues resurfaced?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The problems remain. At a frequency of 5 GHz, the channel is reset to 36. Sometimes, communication with devices connected at a frequency of 5 GHz disappears. I can not connect to the hard drive that is connected to the router. I hope that they will fix the problems in the new firmware ...
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just curious - I actualy have a RAX35 with the same issue I'm powering the router off and on in the AM with a hardware timer. Usually this keeps it fine the whole day but sometimes I still lose internet and have to power cycle the router again Thanks for the update
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is so incredibly frustrating. With everyone trying to work from home and Netgear bricks our routers. I am having all the same issues described here. I will try to put back the older firmware and hope that helps. This is absolutely rediculous.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I can roll back to previous version but that has its own issues minly with access control
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is frustrating,
I have been trying to get RAX 40 firmware .80 to be stable for several weeks and today I downgraded to .64, hoping for the best.
- I have re-started router numerous times, on the worst days at least three restarts.
- Set router back to factory setting twice.
- Disconnected devices one by one.
- Spent hours on the phone with AppleCare tech support.
- Running Apple wireless diagnostic tool in the background generated many logs sent to Apple. Apple says the problem is in the router.
I am hoping for a fix soon.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The router has been stable for over 24 hours after the rollback to FM .64. Wondering if Netgear has ackkowledged the problem because the Nighthawk app and the webapp are still offering to update (or break) the router, see screenshot.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I turned off the auto update function from the router configuration, just got to live with this for a while.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have it working, although I can't tell anyone that it was either pleasant or easy. I have RAX40 in AP mode.
I rolled it back and it worked.
I rolled it forward and it stopped working - again.
I did a factory reset.
I rolled it back.
I did another factory reset.
I rolled it forward.
It started working on the latest firmware.
I think that's a lot of effort for this router - it's incredibly frustrating and disappointing. I think Netgear should pull the new firmware until it gets it right. And Netgear should offer free support to anyone with a RAX40 who is out of time in terms of warranty.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So just updated the firmware and now cannot connect to the router with the app or via a browser. My 2.4 network is showing but nothing can connect to it using the correct passcode. I have no idea how to "roll back" the firmaware, especially when I cannot connect to the modem at all. Why in the world would you allow this piece of crap out into the world completely untested?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Forgot to mention that after the update I got the red flashing "firmware corrupt" error that appeared to have resolved itself after a restart.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you plug in directly? Once I did the factory reset I was able to get in using default logins and a direct ethernet connection. I rolled back the firmware and everything is fine again. I also turned off auto-updates.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello all,
Here is a quick update following multiple failures right after the latest FW update.
- I disabled Smart Connect. I am using (like with previous FW, the same SSIDs for 2.4 and 5ghz)
- I disabled Mix mode WPA2/WPA3 and using only WPA2 AES
3 weeks without any issues.
Hope this help. I stick with the latest FW without any new FW "benefits"...
Best
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
