× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX40 USB Port broken?
jackroberts
Hi I wonder if anyone can help me, I’ve been using the router since December 2021 and everything’s been fine, a few months ago I plugged a Sandisk 256GB USB Flash Drive into it to stream TV shows onto my other devices, in January I upgraded it to a Sandisk 512GB USB Flash Drive, earlier this week we’ve started with WiFi issues (it’s on Virgin Media’s end) and before I knew this I rebooted the router a handful of times using the app and since then I can no longer access the drive from the router, I tried connecting to me laptop to see if the drive was corrupt and no, I tried connecting the old drive that was connected to another device to see if that would work and no, nothing.
Is there anything that can be done or does the router need to be replaced?
Message 1 of 7
Re: RAX40 USB Port broken?
Have you been into the browser graphical user interface (GUI) and investigated the ReadySHARE settings?
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 7
jackroberts
Hi I've checked all of the settings and I've not had any luck getting it to work. The router isn't really acknowledging that it's even connected.
Message 3 of 7
Guru
Did you try factory resetting the router? maybe in the on/off's you were doing, something in the settings was corrupted
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 4 of 7
That was going to be my next suggestion, but it is a bit of a nuclear option. Then again, always a good move when there are post-update issues.
First I'd like to know what @jackroberts finds in the GUI.
Hard to interpret comments like:
Hi I've checked all of the settings and I've not had any luck getting it to work. The router isn't really acknowledging that it's even connected."
Acknowledged where? Windows? ReadySHARE settings?
Then there is the Windows SMB1 challenge. Has @jackroberts considered this?
Solved: ALL Netgear USB Drive Mapping Issues ReadyShareCo... - NETGEAR Communities
Message 5 of 7
jackroberts
Hi again sorry, I’ve been using the web gui and before it stopped working I mainly was connecting it to a Mac using smb protocol. I’ve checked around and it just seems to notice it at all.
I was trying to attach a screenshot of the homepage when on the ReadyShare block it just says “STATUS: No USB drive”
Message 6 of 7
I see what you mean. Not much help there.
D755B88A-4048-4504-8B49-AB3A5423DC4D
Unfortunately, I am too poor/mean to have ever owned a Mac. But I do know that Windows turns off SMB1. You have to turn it back on before Windows can see USB drives on ReadySHARE.
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 501 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
