Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX40 does not save "Disable Port Scan and DoS Protection"
- Mark as New
- Bookmark
- Subscribe
- Permalink
2020-04-17
12:03 PM
2020-04-17
12:03 PM
While debugging an issue with my RAX40 dropping regularly a connection to the Internet, I found out that the setting "Disable Port Scan and DoS Protection" can be set, but it will be cleared again after some time. Like next day it is unchecked again.
And so far all logging entries with regards to DoS are defentily false-possitive, so I suspect this psuedo-protection could be a possible issue in my case.
Is it a bug or a feature that this settings is unchecked/reset back after some time?
Model: RAX40|Nighthawk AX4 4-Stream WiFi Router
Message 1 of 1
Announcements
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
