- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX40 router slower than previous D7000v2 AND Nighthawk app on android very slow FOR RAX40 router
- Mark as New
- Bookmark
- Subscribe
- Permalink
Firmware (according to NH android app) is v1.0.2.46_1.0.1
I purhased this router RAX40 a week ago when my Netgear D7000v2 was having issues and decided to upgrade to his model instead as the shop convinced me this was a better/faster router.
When setting it up online at http://192.168.1.1/start.html, it takes forever to load and equally slow to respond.
When using the Nighthawk android app, that takes forever to load and is slow to respond (pause/resume etc) too!
When I had the D7000v2, I used the Netgear genie app on android, that was fast and responsive.
This router isn't giving me better speed that the previous router. My internet keeps dropping offline, although it generally reconnects immediately, this is driving me nuts.
I am not tekky inclined so please don't give me tech talk, I need layman's terms, equally, I am not tech-dumb, I can follow instructions if they are clearly laid out, preferably with pictures :).
I don't know what to do, I feel like I should've accepted a new D7000v2 instead of being talked into this one.
My broadband plan is fibre 100/20.
I've tried to search everywhere but there isn't a lot of info on this RAX40 to follow, that relates to my issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX40 router slower than previous D7000v2 AND Nighthawk app on android very slow FOR RAX40 route
The D7000v2 is a modem/router. The RAX40 is a router.
What is the modem in front of the RAX40? If it is the D7000v2 then it needs to be in modem only mode. Either that or the RAX40 needs to be in AP mode.
Failure to do that means that you have two routers on your network.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
The RAX40 is a router. To connect to the Internet it needs something. Previously you had the D7000 V2.
What sort of Internet service do you have? What is between your RAX40 and the outside world?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Redtulips7 wrote:
All AX Router's are slower than any AC Router!!! NG will tell you something different to defend their Products!! I am 1 Feet way from the AX120 Router and signal strenth showing 78% where my previous Router X9000 shown 88%
Signal strength does not measure speed.
AX routers need the right wifi clients to gain any speed over AC devices. If you don't have an AX capable client, and don't want to get one, there isn't much point in buying an AX router.
But there is no reason why a non AX client should be slower.
There could be various reasons why people do see a slower connection. But diagnosing what is going on depends on having proper details of the user's network.
In this case @reetzNZ says they have replaced a DSL modem.router, the D7000v2, with a router, and that they have cable Internet.
That just does not make sense. It may be that they are wrong in saying the have a D7000v2. Maybe an R7000?
Or they may have set up the D7000v2 in router mode.
Whichever is the case, we need to know that before anyone can hope to understand why they think their new router is slower.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@reetzNZ wrote:
it's the ONT from Chorus who do all NZ fibre installations
But where did the D7000v2 come into this before you replaced it with the RAX40?
The D7000v2 is modem router that turns a DSL connection – Internet that comes over a telephone line – into local Internet for you.
So the D7000v2 would be no use with an ONT connection unless it is set up to bypass the modem bit.
I'm sorry that I have repeated myself so many times, but after posing the same question three or four times I am getting no nearer to understanding what is going on at your end.
@reetzNZ wrote:
I can't change any of those settings as it's wired to my wall, a cable is plugged from there into my router RAX40 and then powered into the wall socket.
Can't change what settings? The ONT? The RAX40?
What's wired into your wall? The ONT?
You have a cable from the ONT to the RAX40?
Do you still have the D7000v2? Do us a favour, pick it up and look at the label on the bottom.
What does it say in the Model: slot?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@reetzNZ wrote:
I'm not sure whether to respond to this, there is excerpts of comments made and I don't know if you're asking further questions of me but I can assure you I did not get the model of my previous modem/router incorrect, it was D7000v2 not R9000.
I give up.
You said earlier:
it's the ONT from Chorus who do all NZ fibre installations,
By default, the D7000v2, a modem/router, will not work through an ONT. That is an Optical Network Terminator. They sit on networks that have an optical cable delivering the Internet. The D7000v2 is a DSL modem/router that gets the internet over a copper cable.
I apologise for the distraction that @Redtulips7 introduced. It is kn oiwn as "hijacking. I just wanted to correct any misinformation that they introduced. You can safely ignore their messages and any replies to them. They have nothing to do with your problem, which is why hijacking is against the rules.
NETGEAR Community Terms Of Service | Answer | NETGEAR Support
- Behave with civility and mutual respect. Flaming or name calling will not be tolerated. Similarly, any message containing the following will be removed at the discretion of either a Community moderator or administrator:
- Off-Topic posting
- Thread hi-jacking
Back to your issue. Knowing what is happening depends on a proper understanding of your network. I am completely baffled. You say you are replacing a device that should not have worked at all with your optical Internet service. It is like saying you are trying to get a boat to cruise along a motorway, or a car to travel down a river.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Anyway the D7000 was used prior as an access point but it's no longer in use so I can't keep referring to it, it's just that I got better speed when it was in use. What can I do to get the RAX40 doing a better job? Or should I be considering taking it back and swapping again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@reetzNZ wrote:
Anyway the D7000 was used prior as an access point ...
Access Point or router?
They are very different.
If it was an access point, providing only wifi, then it was connected to a router.
@reetzNZ wrote:
...it's just that I got better speed when it was in use.
Wifi speed? With what devices? 2.4 Ghz or 5 GHz?
How fast is your internet? What speeds do you get with wired devices?
Wifi speeds are notoriously difficult to measure and compare.
How did you test the speeds.
That's your call, but you may end up with the same problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello reetzNZ - Have you gotten a chance to contact our support team for assistance? Your router is provided complimentary support.
https://www.netgear.com/support/default.aspx
~Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks for your advice Christian, I actually didn't think of that myself but I am concerned they might ask me questions (techy type questions) that I wouldn't know how to answer. I'm still weighing up my options, I'm actually thinking about taking the router back given everything is slower than it was with my previous router, including using the associated android Nighthawk app.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@reetzNZ - Our support team assists all customers with all levels of technical knowledge. Please feel free to contact our support team or send me a message with your contact info and I can assist with support reaching out to you.
~Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@reetzNZ wrote:
Thank you Christian, I appreciate the few who tried to assist me but out of frustration as there was too much focus on my previous router/modem, I found it too difficult to keep up with the assistance on offer and filter out the highjackers. I think the best advice I got was to utilise the free three month assistance line. Anyhow apart from the actual RAX40 router, the Nighthawk android app was unbelievably slow to use to allow me to manage my children's internet time, turn their devices off etc., it just wasn't responsive and took too long to process. Anyhow, I had been so loyal to Netgear but I took the router back, got a credit for it and have since purchased a Synology one which is great, fast internet speeds, very awesome phone app with immediate response upon each click and very customizable. So again thank you and everyone else who tried to help me. Regards, Rita
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yes yes
