×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
RAX45 Wi-Fi losing internet connection
Lonzo96
Follower
I have a Netgear Nighthawk AX4300 RAX45 router that will randomly lose internet connection on wireless. My computer has a wired connection and will continue to have an internet connection while my iPhone is connected to the router but will lose internet connection. The issue will usually subside after a couple of minutes but I'd like to fix the issue once and for all.
The router has the latest firmware from Netgear installed, version V1.0.4.100_2.0.64.
Message 1 of 4
Guru
Re: RAX45 Wi-Fi losing internet connection
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wif...
 Please include ISP modem/ONT brand and model there as well.
Thank you
My Setup ISP SparkLight | Internet Cable 1000↓/50↑ CAX30 Mode Mode  | Wifi Router RBK963 and RBK853 Router mode | Switches NG GS105/8, GS308v3, GS110MX and XS505M | Additional NG HW: C7800/CAX3/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: MK63, R7000, R7800, R7960P, R8000, RAXE500, RAX120v2, RAX50v2, XR450/500/700/1000, EX7500/EX7700
Message 2 of 4
DarrenM
Sr. NETGEAR Moderator
Message 3 of 4
Drew-M
Do you have QoS turned on? If so try turning it off. Was experiencing similar issues with my 5g band but haven’t had an issue since turning QoS off
Message 4 of 4
Discussion stats
  • 3 replies
  • 1235 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 6E
