× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
RAX45 missing Remote Management option under Advanced Setup
amonynuts
Apprentice
Model:  RAX45-100NAS Nighthawk AX6 AX4300
Firmware:  V1.0.4.100_2.0.64
In the routerlogin.net configuration menus, I find no option to enable Remote Management under Advanced -> Advanced Setup or under Advanced -> Web Services Management.
Is Remote Management no longer available on Nighthawk routers?
Message 1 of 4
Guru
Re: RAX45 missing Remote Management option under Advanced Setup
Remote Mangagment was removed from NG routers. I believe it may have been due to a security concern. So there using the mobile NH app and Access Anywhere feature on the app to be able to remote in to the router using the Nighthawk app.
Message 2 of 4
amonynuts
Apprentice
That's unfortunate since the Nighthawk app doesn't run on my laptop/desktop computers, and doesn't allow modification of many configuration settings.  Thanks for the info.
Message 3 of 4
Guru
Ya, for any advanced configuration changes, you'll need to be local with a PC or laptop and web browser.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1068 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
