- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX48 dropping connections, then reassigns new IP
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a brand new RAX48 from Bestbuy, the router is dropping connections, ALL THE TIME, then reassigns new IP, so mappings no longer work... Im about to send it back... Junk so far.
Its running the current firmware.
Mike
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX48 dropping connections, then reassigns new IP
What actual version number is on it?
What modem/gateway is it connected to?
since setup/firmware updates has a factory reset and clean install ever been done? (should have auto-updated after install)
The RAX line came out before the AX spec was even finalized. They've responded favorably to factoy resets and clean installs after firmware changes.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Firmware rev. is V1.0.2.72_2.0.45, the unit did complete a firmware when installed, about two weeks ago.
The modem is from Spectrum Communications, model E31T2V1.
Are you suggesting I do a factory reset and reconfigure back to my settings?
Thanks,
Mike
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am. The RAX got significant firmware changes since release. Its a reasonable first step.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Okay, I'll try that at 6pm ET tonight after my meetings, I will post when completed and if the issues is mitigated.
Many thanks,
Mike
- Mark as New
- Bookmark
- Subscribe
- Permalink
If it doesn't work, I'd get in contact with support (if still in your 90 days free window). Thats the only firmware version showing available but maybe there's a beta version or could be a hardware issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
My meeting was cancelled, I just reset to factory and established my local settings.
I appreciate your support, if this does not work, I want to take the product back, Im not interested in beta testing over the counter products that should be fully vetted and tested.
Thanks,
Mike
- Mark as New
- Bookmark
- Subscribe
- Permalink
It worst, I just reconnected laptops, iPhone, iPad, Alexa devices, even the Nighthawk app will not connect!
I'm willing to try one more, after that its going back.
Mike
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try re-installing the firmware to it. A factory reset only removes settings. If something was corrupt from the start, reinstalling the fimrware is needed to overwrite it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I will try to reintsall the firmware if that does not resolve, I'm done, its going back.
Mike
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did a harware reset, downloaded and reinstalled the firmware, did another hardware reset.
Config to my network, retablished 18 smart devices from Alexa to Sensi thermostats, all devices stayed connected last night, so far so good!
Any other recommendations?
And thank you, I pulled out the receipt and box last night I was done with the RAX48, it has been nothing but issues.
Mike
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Mjdoyle wrote:I did a harware reset, downloaded and reinstalled the firmware, did another hardware reset.
Config to my network, retablished 18 smart devices from Alexa to Sensi thermostats, all devices stayed connected last night, so far so good!----Glad to hear it!
Any other recommendations? ----Not really. Its a pretty solid router but it sound like you must have had a corrupt firmware installed or maybe something happened during shipping. its why a reinstall of firmware is worth a shot.
And thank you, I pulled out the receipt and box last night I was done with the RAX48, it has been nothing but issues.----Again, glad you have it up and working well! Stay safe!
Mike
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks again, appreciate all of your support.
I did discover a bug this morning in the Nighthawk iPhone app, as I added my devices lasynight, I applied a logical name and appropriate icon, this morning the logical name stayed, however the icon has changed to network on almost all connected devices.
Mike
- Mark as New
- Bookmark
- Subscribe
- Permalink
The connected devices page on the app and gui has been an on/off issue for multiple routers. it wouldn't surprise me (just disappoint me).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Im in the software business, I get it, just don't like it.
Thanks,
Mike
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you get to solve it?
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
