- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX50 external outdoor antenna
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm looking for an external antenna that would be used outdoors with the RAX50. We are having problems with speed and range going through walls.
Thank You
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX50 external outdoor antenna
what are you actually trying to do? The descrption left a little to be desired.
Attach an antenna to it that you can run the wires through the wall and have them outdoors?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Exactly...we need to run a tablet outside, and right now the range on the RAX50 is being hampered by the outside walls. I know there are third-party outdoor antennas on the market, but is there one that NETGEAR suggests?
- Mark as New
- Bookmark
- Subscribe
- Permalink
No there isn't. Netgear doesn't sell that type.
Usually you have to find a 3rd party vendor that does have the same matching antenna design and a long enough cable to do what you're attempting.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
