× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX50 nat moderate and packet burst
setrio
Hi,
I just bought a RAX50 and I can't get the nat to open in games. Also, I get tons of packet bursts at the point of being unplayable (testing on COD: Warzone).
Tried to set NAT to open, enabled/disabled uPnP and port forwarding without luck. Also, disabled the protection app just in case and nothing changed.
I don't care much about nat to be open but packet bursts are a concern since I can't play any multiplayer game at this point. The issue is with the router because I had a Linksys before without any issues, so...
Any ideas? Any help would be appreciated
Message 1 of 8
Accepted Solutions
setrio
Re: RAX50 nat moderate and packet burst
I finally just returned the product, it didn't work and support was useless
Message 8 of 8
All Replies
Guru
what modem/gateway are you connected to?
Message 2 of 8
setrio
none, it goes directly to the wall jack from the internet provider.
Message 3 of 8
Guru
And that jack has something connected to it.
Message 4 of 8
setrio
Maybe I explain it wrong, my english is not good, sorry about that. The modem goes directly to the white box on the wall that is just a relay or something like that, there is no router or anything like that between the RAX50 and "the internet".
Message 5 of 8
Guru
that white box has something converting from fibre to ethernet.
Just trying to determine if that "white box" has other functions built into it
Message 6 of 8
setrio
I'm pretty sure it doesn't, I checked with the internet provider and they said it shouldn't be a problem. My english is bad but I have some knowledge in the matter, so I'm pretty confident that the "white box" is not the issue. Either way thanks for trying to help, I really appreciate it.
Message 7 of 8
setrio
Message 8 of 8
Top Contributors
Discussion stats
  • 7 replies
  • 1765 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
