- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX50's SSID reverting to default
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi,
Without any warning, my router SSID reverted to their default value tonight. Automatic update is enabled. My firmware version is 1.0.12.120_2.0.83. A quick search on NetGear web site doesn't provide any information for this version.
The Guest SSIDs and passwords didn't change.
Can someone confirm that there was indeed an automatic update that screwed my SSIDs? Or is this a known issue?
Thanks in advanced,
Mike
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX50's SSID reverting to default
Can we confirm it 100%? No.
but there's been several posts already today about it so I'd be suspecting something like that versus other issues.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Applicable to 6 GHz devices only: Only use the device indoors. The operation of 6 GHz devices is prohibited on oil platforms, cars, trains, boats, and aircraft, except that operation of this device is permitted in large aircraft while flying above 10,000 feet. Operation of transmitters in the 5.925-7.125 GHz band is prohibited for control of or communications with unmanned aircraft systems. Panorama Charter Spectrum
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Factory reset the router and setup from scratch. Might manually load FW to the router using MS edge or Firefox with a wired PC, then after it's loaded, factory reset and setup from scratch.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
@MLBmn wrote:
Same exact issue. Firmware V1.0.12.120_2.0.83
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @mjlemay @microchip8 ,
Does your wi-fi SSID/ passphrase contain " ", space or any special character ?
