- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX70. Changing to 10.0.0.1
- Mark as New
- Bookmark
- Subscribe
- Permalink
Router set to 10.0.0.1. Went into advanced settings and checked off router mode several times and saved config. Rebooted and still 10.0.0.1. Had no choice but to hit the reset and start over…. This day 2 of installing the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX70. Changing to 10.0.0.1
Why not just use access point mode if you're wanting dhcp disabled?
- Mark as New
- Bookmark
- Subscribe
- Permalink
A sign that the RAX70 is behind another router and the setup process is trying to avoid problems.
What is Double NAT? | Answer | NETGEAR Support
and
How to fix issues with Double NAT | Answer | NETGEAR Support
Or just go for AP mode as @plemans advises:
How do I change my NETGEAR router to AP mode? | Answer | NETGEAR Support
Or explain exactly what you are trying to achieve with this juggling trick.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
1. we're not netgear.
2. if you're disabling dhcp and don't have another router connected, of course you're going to have issues. A modem only device needs a router connected thats handling dhcp/nat. If you're disabling that, what result do you think you'll get?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Johncorsaro wrote:
Not running behind another router. Is connected directly to cable modem that has no router capabilities.
So why are you trying to disable the router bit of the RAX70?
What do you expect to carry out that function for you you on your network?
What is this anonymous cable modem?
And, as I suggested before:
"explain exactly what you are trying to achieve with this juggling trick".
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
