× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX80/EAX80 stops responding
ndanger69
Tutor
Hardware VersionRAX80
Firmware VersionV1.0.3.102_1.0.48
GUI Language VersionV1.0.3.102_2.1.46.1
          CPU Load
CPU1: 2.88% CPU2: 1.70% CPU3: 1.76% CPU4: 1.76%
          Memory Usage (Used/Total)
420MB/882MB
          Flash Usage (Used/Total)
52.00MB/512.00MB
          Network Session (Active/Total)
3917/65535
          System Uptime
0 days 13:25:23
About once every 36 - 48 hours my router will stop responding and will lock up so that you cannot get to the web interface.  I have to power cycle the device to get it to come back.  When this happens, I can look at the logs and see the following.
[Time synchronized with NTP server] Monday, Sep 28,2020 02:47:06
Wednesday, Dec 31,1969 12:00:00
Is anyone seeing anything similar or have any ideas as to what to try?  It almost feels like a memory leak, but the memory usage as detailed above is not terrible.
Also, is there a way to setup a scheduled reboot or is there a way that I can telnet into the system via a script activated via a CRON job?
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 6
Christian_R
NETGEAR Employee Retired
Re: RAX80/EAX80 stops responding
ndanger69,
Did this occur recently? May you revert to the previous firmware version and let us know of any changes.
https://kb.netgear.com/000061902/RAX80-Firmware-Version-1-0-3-88
Christian
Message 2 of 6
ndanger69
Tutor
This has been occurring for at least the last 3 - 4 firmware revisions so I doubt that rolling back is going to resolve this issue.
Message 3 of 6
redparadox
Guide
I too am running the latest firmware revision on the RAX80 (V1.0.3.102_1.0.48).  I can usually expect a complete crash and restart at least once a day.  There is something fundamentally wrong in the firmware that is causing this issue.  I too see entries like this in the logs after the crash:
[DoS attack: Fraggle Attack] from source 24.158.80.1,port 67 Thursday, Oct 08,2020 07:33:28
[DoS attack: Fraggle Attack] from source 24.158.80.1,port 67 Thursday, Oct 08,2020 07:33:07
[DoS attack: Fraggle Attack] from source 24.158.80.1,port 67 Thursday, Oct 08,2020 07:32:46
[DoS attack: Fraggle Attack] from source 24.158.80.1,port 67 Thursday, Oct 08,2020 07:32:28
[DoS attack: Fraggle Attack] from source 24.158.80.1,port 67 Thursday, Oct 08,2020 07:32:07
[DoS attack: Fraggle Attack] from source 24.158.80.1,port 67 Thursday, Oct 08,2020 07:31:46
[DoS attack: Fraggle Attack] from source 24.158.80.1,port 67 Thursday, Oct 08,2020 07:31:27
[DoS attack: Fraggle Attack] from source 24.158.80.1,port 67 Thursday, Oct 08,2020 07:31:06
Wednesday, Dec 31,1969 19:00:00
Great that it is blocking the attack, but it would appear to me there is a buffer overflow problem somewhere in the firmware and it has been there through the last several firmware updates.  Netgear, it would be great if you provided some sort of tool/utility that we could help you solve this.  Similiar to the crash reports that Apple/Microsoft allow you to send.
Message 4 of 6
Gueven
Same problem with eax80 with rax200.
My eax80 freezes often (about 1-3 days).
Reboot is needed.
Message 5 of 6
880911ck
I thought it was just me!!!
This has been happening to me to forever now. This router is always locking up and I constantly have to reset it.
Message 6 of 6
Discussion stats
  • 5 replies
  • 1461 views
  • 2 kudos
  • 5 in conversation
Announcements
Orbi WiFi 7
