×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
RAX80 - Extremely slow internet download speeds
chrisridge
I just installed my Nighthawk AX8 router that I have connected with Comcast/xFinity with 1.0 Gbps service.  My wifi connection are good and stable, but the download speeds are severely limited to 1-2 Mbps on all of my devices.  The FW version I have is the latest - v1.0.3.102 that I had update during set-up.  I have tried enabling QoS, I have tried enabling ipV6 and nothing seems to help.  Is there any settings that would limit the internet bandwidth like this?  I would hate to have to return this item.
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 4
Guru
Re: RAX80 - Extremely slow internet download speeds
A couple things.
what modem/gateway do you have from comcast?
since its a new purchase, it probably updated its firmware. the RAX devices respond favorably to a factory reset/reinstall after changing firmware. Have you tried this? (i know its new but it should have auto-updated on install)
What speeds do you get hardwired in?
What speeds over 2.4ghz?
And 5ghz?
What site/device are you testing on?
you also might post in the AX forum for better help.
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wif...
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 4
chrisridge
Replies in bold below
what modem/gateway do you have from comcast?  I have my own cable modem.  A Netgear CM1000
since its a new purchase, it probably updated its firmware. the RAX devices respond favorably to a factory reset/reinstall after changing firmware. Have you tried this? (i know its new but it should have auto-updated on install)  I have done a factory reset twice
What speeds do you get hardwired in? I haven't connected to the hardwired ports yet
What speeds over 2.4ghz? 1.0 - 2.0 Mbps
And 5ghz? 2.0 - 3.0 Mbps
What site/device are you testing on? Tried speedtest.net, xfinity speed test, and Ookla.  They all say my speed sucks.
Message 3 of 4
Guru
If you connect a device directly to the modem, what speeds do you get?
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 647 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
