- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX80 Firmware V1.0.1.56_1.0.23 needs work!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not even sure where to post this since my model number is RAX80. Anyway, the QOS sucks, and the DHCP must be screwed on firmware Firmware V1.0.1.56_1.0.23. Or the http interface doesn't update if you hit refresh.
Tried to call tech support to tell them problems with the firmware but I get level 1 telling me if I tried resetting the router.
1. If I set QOS to Highest it some how resets for the device and even changes the label i've assigned to it.
2. Problems with my smart devices because the iptables must not update correctly for wired devices.
3. Labels assigned with edit button on administration/attached devices wont save for some reason.
Bought this new router cause all the advertising says it can handle more smart devices, seems to crash all the time. I'm ready to to send it back.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX80 Firmware V1.0.1.56_1.0.23 needs work!
Return it. You're basically beta testing at the moment. Don't immediately jump on the latest and greatest but wait for things to mature, especially on the firmware side. It's also a model based on a draft and does not support a few things in the draft - no idea if they'll be added eventually
- Mark as New
- Bookmark
- Subscribe
- Permalink
How comes the RAX80 (AX8) and RAX120 (AX12) are still not available as models to select here on the Nighthawk Routers community section, dear @ChristineT ?
1. If I set QOS to Highest it some how resets for the device and even changes the label i've assigned to it.2. Problems with my smart devices because the iptables must not update correctly for wired devices.
Why do I don't wonder for a second? All foir items listed read like a fil-rouge of random issues Netgear has with many different consumer routers for a longer time - not to much specific to the RAX80 (AX8). Issues come and go and return with firmware updates. Worst firmware quality in the consumer router market - not acceptable for expensive leading edge Nighthawk routers. Return it, and post negative feedback. Otherwise Netgear will never wake up.
@Altsai @Christian_R make this consumer business unit do a proper job! It's just beyond of just ridiculous.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the exact same issues on firmware 1.0.1.40. Just upgraded to 1.0.1.56 today. Attached devices labels don't work. Some stick around, some revert to default immediately, and most revert back to default over a period of time. I can only get maybe 20% of the labels to stick. Likewise, QOS settings sometimes revert.
I have not had any issues with wired devices, but I have endless problems with wireless devices. After a period of time (2-3 weeks), it's like DHCP just goes to crap. Devices can't/don't get addresses anymore (I use static reservations for my devices), and gradually all of my wifi devices drop offline until practically nothing in the house works. The only solution is to manually reboot the router. That fixes everything for a couple weeks. Wired devices work fine, it's something with wifi only.
Likewise, the only solution I've been given is reset the router and set everything up all over again.
- Mark as New
- Bookmark
- Subscribe
- Permalink
No surprise on these issues. These have been on the older routers and not fixed so why would we expect them to be fixed now?
Netgear engineers have not been able to address the on going issues so why would they suddenly be fixed now?
If within return window do it and get something else, IMHO.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good luck, and be prepared Netgear will ask you for a factory reset as part as their support scripts. Same problem for several generations of Netgear routers - Nighthawk, Orbi, now Nighthawk AX, ... figure. @ChristineT @Christian_R @Altsai how comes Netgear does ignore the community users that baldy - for years?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Orbi & filasd,
I would like for support to get in contact with you/have them follow up on your case for further investigation. Please send me a PM with your contact info and case number (if applicable).
~Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
I bought the router a couple of days ago and it freezes 3 times a day. Im running this firmware. I have put my old router back until i can get this fixed. If you compare the pricepoint of routers to other types of hardware the quality of routers is a **bleep**show. The firmware thing has gotten out of hand where things are pushed out with little quality control. I am really disapointed in this purchase. I contacted support but apperantly the normal support does not handle RAX routers for some reason and someone is going to contact me by email. Its ok with minor bugs but since now days a whole family with devices, computers, home automation relies on a stedy connection to the internet its not acceptable to freeze several times per day. It just drops all connections and is not possible to contact it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello pure_x01 - Please send me a message with your case number. I'd like to help with getting your support case on track.
~Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello necrocis - Have you contacted support regarding your issue?
https://www.netgear.com/support/default.aspx
~Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
Just created an account to chime in here:
I bought my RAX80 about a month and a half ago. Things have been mostly, OK. I updated to the most recent firmware here, and have had constant disconnects. The router lights show connected to internet, but none of my devices can connect to the wireless network, and my wired connections are dropped entirely.
Pretty let down so far for a $400 router 😕
- Mark as New
- Bookmark
- Subscribe
- Permalink
~Christian
No, I reverted the router back to v1.0.1.40_1.0.22 and waiting to see if it exhibits the same symptom. I've been using the factory default WiFi password, but my own SSID (Battery Garden East). The LAN connections never drops, only WiFi. I also noticed if a device doesn't leave the wireless range it will stay connected but if it any device needs to reauthenticate it'll state invalid password. This is slighty different to what I was experiencing prior, before I had to literally change my WiFI password, with v1.0.1.56_1.0.23 a P/C corrects the issue.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello necrocis - Thank you for the update. Curious to know how reverting back has turned out for you.
Hi Bubblecat - Have you gotten a chance to contact support for your newly purchase device? https://www.netgear.com/support/default.aspx
~Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
I haven't contacted support. I have reverted my firmware about 5 days ago and my disconnects have pretty much ceased. There was one instance where I manually had to power cycle the router, but since then no drop outs or disconnects. I'll definitely will be skipping V1.0.1.56_1.0.23
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi necrocis & BubbleCat - Thank you for the update.
~Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
New product like this should have not needed revision to older firmware. Netgear really needs to get their act together especially when it is their new flagship product. Fire the 3rd party folks and bring the firmware back in house. There does not seem to be any testing before firmware is released. With other products the same obvious problems are present from update to update. That should not happen. Obvious problems should be fixed by testing and applying fixes before release.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi all
I am having this router for 2 months and lateast firmware V1.0.1.56_1.0.23, the VPN cert download just don't work at all which bring you to the loop of password prompt. Moreover, the WIFI/LAN connection is not stable which I frequently need to reboot the router by power cycle. I wonder if this firmware is faulty and would like to know how to revert back to older firmware. I am very disappointed on Netgear and this router is not cheap at all!
Ken
- Mark as New
- Bookmark
- Subscribe
- Permalink
Same here with the firmware issues. tested multiple times.
first off with the VPN Cert download, there is a workaround. If you have Remote Managment on , turn it off.
Speeds.. with QOS, Traffic Meter, Access Control all OFF.
Firmware- V1.0.1.56_1.0.23
Down - 419
UP - 430
Firmware- V1.0.1.40_1.0.22
Down - 945
Up - 754
I have been back and forth with the firmware several times. checking different settings.
It will not work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Netgear at it's best again @Christian_R @ChristineT - feed these issues to the people in charge please!!!
Nice find, obviously a recursion - happened several times over the years on other Netgear routers.
@SereneStorm wrote:
Speeds.. with QOS, Traffic Meter, Access Control all OFF. ...
That's the no so nice part ...
- Mark as New
- Bookmark
- Subscribe
- Permalink
This router needs an telnet/SSH option like most Nighthawk routers on the debug page in my opinion.
