× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX80 Logs
dehinson64
Guide
RAX80 Logs
Hello,
I have intermittent problems with my RAX80. Sometimes the internet drops, cannot log into router hard-wired, internet speed drops to 10mbps. So, the only things I can do is re-booted the router manually.
Anyway, I go into the router to review the logs to detemine issue. But the log starts from after the re-boot. I cannot see the logs from prior to the re-boot.
Is there a way to see the logs prior to the reboot? Is this a confuguration option?
If not, Netgear get this done in the next firmware update!  This is getting on my nerves!
Regards, Dean.
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 5
dehinson64
Guide
Re: RAX80 Logs
Also, why does FAST.com show that I have over 220mpbs internet speed and when I use SpeedTest while dialed into the router, I tells me only 25mbps.  Netgear, I am about to go ask for a refund and gt a different router from another company!
Message 2 of 5
microchip8
Master
Re: RAX80 Logs
You are beta testing. All RAX models have firmware issues and do not support a few important WiFi 6 options and it's not sure they'll be added at all, if possible. I do not recommend getting any AX routers from any vendor at this point in time, unless you want to beta test and throw money out the window
Message 3 of 5
Retired_Member
Not applicable
RAX80
Mine too
I upgraded to improve network strength in my small apartment but it is worse than my previous network router
Do Netgear respond to posts on here? Or do I need to post on whirlpool.net?
Message 4 of 5
antinode
Guru
Re: RAX80
> [...] Do Netgear respond to posts on here? [...]
   Not reliably, but you might find/get more/better information in a
more appropriate forum for your router:
      https://community.netgear.com/t5/x/bd-p/en-home-routers-nighthawk-wifi-ax6
Message 5 of 5
Discussion stats
  • 4 replies
  • 1531 views
  • 1 kudo
  • 4 in conversation
Announcements
Orbi WiFi 7
