- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
RAX80 / RAX75 Firmware 1.0.1.70 Problem
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX80 / RAX75 Firmware 1.0.1.70 Problem
The latest firmware for RAX75/80 is 1.0.2.76 http://www.downloads.netgear.com/files/GDC/RAX75/RAX75-V1.0.2.76_1.0.35.zip
- Mark as New
- Bookmark
- Subscribe
- Permalink
You have joined in on an existing conversation that may or may not have anything to do with your problems. You aren't even using the same hardware, according to your footer.
There is also a good chance that the official support team is busily monitoring new conversations and may miss your addition to this one.
If you do want help with your problem, check previous stuff that may be related then start your own discussion.
If you do decide to ask a question, you should provide more details and your own version of the information that the forum suggests that you provide. For example, as this is a router, it helps to know what modem you are using and the various things that you have tried to fix the problem.
You talk of a "power reset". If you mean power recycling (on/off), then a proper reset might be in order.
If you visit the support pages:
Support | NETGEAR
you can feed in your model number and find the documentation for your hardware.
If you need more help, you might get better and quicker replies, and find other answers, over in the appropriate section for the R8000:
Nighthawk WiFi Routers
- « Previous
- 1
- 2
- Next »
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
