- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX80 Router with Nighthawk Mesh
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am currently using a RAX80 router. Unfortunately, there are a couple of areas in my home where the router frequently drops the WiFi connection. I'd like to add a MK62 mesh system to extend the wireless network rather than replace it.
I have previously setup a MK63 mesh network on a FiOS router. In that situation, I disabled the wireless network on the FiOS router. The MK63 system is providing the only wireless network in that house.
How would I set up a system where the MK62 units work with RAX80 router?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX80 Router with Nighthawk Mesh
The RAX80 isn't a mesh device so won't function as integrated with the mesh system.
but you can go
modem--->RAX80----->mk system (in access point mode)
just give the rax80 a different ssid and use different wireless channels to prevent interference.
then you can have the close devices on the rax and the devices that need range on the MK system.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for the guidance. I have commandeered my father's MK63 equipment and am testing it now. Essentially, I have two wireless networks operating in the same space. Not quite what I wanted, but close enough.
The channel settings on the RAX80 are: Auto @2.4GHz and 44 @5Ghz.
The channels used for the MR60 are: Auto @2.4GHz and 153 @5Ghz.
I am not observing any conflicts. The MR60 network is very fast, and, thus far, reliable. But the RAX80 wireless remains temperamental. I had expected better performance from the (expensive) RAX80. Skimming through the discussions in this community, I see that others are having similar issues. I'll do some reading and see if the RAX80 performance can be improved before permanently adding the mesh system.
