× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
RAX80 Slow Wired Speeds vs. Modem
spikyllama57
I currently have 1000/1000 service through an ISP called EverywhereWireless. I have my router plugged in to an ethernet jack that supplies the speeds to my unit and from the jack itself, I'm getting around 800/800 (this is due to my building having some wiring issues that are getting resolved to provide the full speeds).
However, through the router hardwired to my Mac running 10.15.3, I'm only getting around 500/700 speeds. Trying through a PC running Windows 10 also nets the same results. The upload speeds are pretty close to what I'm getting through the jack, but the download speeds are significantly slower.
I'm not running QOS or Traffic Meter
Currently running FW 1.0.1.70
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 7
zmon
Guide
Re: RAX80 Slow Wired Speeds vs. Modem
It's sort of a known issue at this point. https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/RAX80-slow-speeds/td-p/1802095/pag...
You can enable, then disable, QoS and speeds will go back to normal for a short time. Restarting the router also has the same effect. My own RAX75 just halves the download speed for the most part, while upload is pretty much typical of what I'd usually get.
Message 2 of 7
spikyllama57
Thanks for the link! I might try one of the suggestions which is manually set the bandwidth - but if, like you say, it's only a short-term fix, then maybe a different router is the actual solution for now...
Just disappointing that there are so few AX-capable routers and I thought I was future-proofing myself by picking up the RAX80.
Message 3 of 7
LastStand
Initiate
I've have the same problem.  The router (RAX75/RAX80) can't exceed 480-530Mbps via Ethernet even with 1 gigabit service.  I can plug in my old ISP router and instantly get 1Gbps, switch it over to RAX75 and get about half the speed.  Same cables, same server, etc.
I've been fighting this thing for months and should've returned it.  Sadly, I'm passed the return window (and the 90 day support window - $400 router but only 90 days?).
Anyone considering buying the RAX75/RAX80 should avoid if you have or ever are planning on getting Gigabit Internet Service.  So far the Router cannot saturate this speed and after numerous firmware updates, it hasn't been fixed so it may even be hardware/design related.  I hope it can be fixed via firmware but I'm probably just going to buy another $400 router from another company and take a sledge hammer to the RAX75/RAX80.
Message 4 of 7
LastStand
Initiate
Just to update:  Netgear Support was unwilling to escalate my ticket to a Level 3 tech without first going through the RMA process.  So I had another RAX75 shipped to me, swapped out my RAX75 for the one received from Netgear and performed speed tests.  Still the WAN download speed maxes out at around 490-510Mbps via Ethernet.  Replacing the RAX for ISP Router and I get the 1Gbps WAN download speeds.
Now double-confirmed it is the Router and/or Firmware.
A $300-$400 Router shouldn't have these problems and I find them unacceptable.  If you have, or ever plan on getting, Gigabit Internet Service, I highly recommend buying a Router from a different manufacturer.
Message 5 of 7
mayeen12
Star
I finally fixed my problem
Final Results, I'm getting FULL 940 to 985 MBPS download (From Internet & Internal NAS Drive) - both in wired and wifi mode.
PLEASE NOTE** All my clients are wired or AC or AX devices.
Step 1 - Get the latestest firmware
Step 2 - Turn OFF QOS
Step 3 - Turn OFF Traffic Meter
Step 4 - Turn OFF Access Control
Step 5 - Test you MTU from a wired connection > https://kb.netgear.com/19863/Ping-Test-to-determine-Optimal-MTU-Size-on-Router
Step 6 - Adjust your MTU settings >> https://kb.netgear.com/24015/How-do-I-change-the-MTU-size-on-my-Nighthawk-router
Step 7 - Use WiFI Analizer - FIND THE BEST CH for WiFI - I put AUTO for 2.4 and CH36 for 5ghz
Step 8 - ENABLE BEAMFORMING > DISABLE MUMIMO > ENABLE AX
Message 6 of 7
FinnedM91
This solution worked for me, thank you very much!
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 3429 views
  • 5 kudos
  • 5 in conversation
Announcements
Orbi 770 Series
