- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAX80 VPN on Mac
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
@bmfkai wrote:
Is there any documentation on how to get the native MacOS VPN client connected to VPN on the RAX80?
No, because Netgear is using OpenVPN, what is not compatible with the Apple supplied IPSec which comes in three variants on Mojave (10.14):
- L2TP/IPSec
- IPSec/IKEv2
- Cisco IPsec
The first two represent the "real" standardized VPN with available IETF RFCs, Cisco is obviously partially proprietary. There was some rumour that Apple might support some SSL VPN natively, but this has never happened for now.
OpenVPN is SSL/TLS based, so some parts of the transport are IETF RFC'ed, but not the overlaying system - so a complete different technology - requiring dedicated clients, as nicely documented and explained e.g. with OpenVPN (commercial) Access Server -> Connecting to Access Server with macOS
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAX80 VPN on Mac
Edit: I managed to get OpenVPN working... the config had the wrong extension for one (needs to be .ovpn), not sure why the router serves up a .conf file instead (assuming "non-Windows" means Mac or Linux) and still directs users to use OpenVPN. I also had to change the config to use TUN instead of TAP and change the port appropriately. Maybe TAP is no longer supported by OpenVPN? If that's the case then the documentation and files provided by the router should be updated to reflect this.
I would still like to know how to get this working with the native VPN client though, if possible.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi bmfkai - I'll check with the team and provide an update as soon as possible.
~Christian
- Mark as New
- Bookmark
- Subscribe
- Permalink
@bmfkai wrote:
[for whatever reason this forum wouldn't let me edit my initial post after sitting idle for only 2 minutes... ]
This capability is not enabled on the "Nighthawk Routers With WiFi 6 (AX)" community section, indeed. Complained several times already ... @Christian_R please.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- L2TP/IPSec
- IPSec/IKEv2
- Cisco IPsec
