×  Introducing Nighthawk RS700 WiFi 7 (BE) Router. For more details, please visit Nighthawk Tri-Band WiFi 7 Router.
Reply
RAX80 Wi-FI very slow
MadBrewer62
I have a RAX80 with firmware V1.0.4.120_1.0.61 the wired wifi is around 896 MBs while the wi-fi on 3 diffrent devices is arounb 280 MBs this is with either 2.4 0r 5 Gh connections, I have swapped aroung channels with no diffreances, It does not matter id QOS is enabled or disabled.  The device os are windows 10, Apple 14, and  Android, which are all arounf 200-280 MBps.  how to I fix this to make it consistent
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 2
Guru
Re: RAX80 Wi-FI very slow
you told us the operating system you're testing on but not the device you're using.
That's kind of key as mosts devices are either 1x1 antenna devices or 2x2.
Also, I'm impressed if you're hitting 280mbps over 2.4ghz. I've been maxing out around that 90-110mbps over the 2.4ghz on a RAXE500, RAX200, and my CAX80. So I'm curious how you're testing your speeds since 2.4ghz is a much slower network.
Current setup: CM2000-> RBKE963B-> Trendnet TEG-S380-> GS716T-> pi-hole
also in AP setup: RAXE500->EAX80
1.4gig download/50mbps upload from Xfinity
We’re members of the public helping out on our own time.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 472 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
