× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX80 Wired Ethernet Speeds are terrible
Scotty777
Tutor
Firmware Version V1.0.3.106_1.0.50
Speed Tested with Speedtest.net and withing the Nighthawk App on my iPhone11Max with the latest Software and using the same server that is 12 miles from my home.
This Router worked like a CHAMP when purchased in August of 2020, wired and wireless speeds were near max capacity for my ISP (which is not great but we live in a rural area) and the whole family was very happy. Several firmware updates later and the Ethernet speed is complete trash. I seached this forum and found a couple of threads that seemed to address this issue. However, upon performing the actions suggested, Toggling QoS, Factory Reseting and they toggling QoS, rebooting many, many times, this issue remains.
Speedtest via Ethernet
Ping 27, Download 17.48, Upload 2.14
Speedtest via iPhone using Speedtest App
Ping 28, Download 117.3, Upload 11.0
Speedtest via Nighthawk App
Ping 26, Download 122, Upload 10.2
Not sure what else to do at this point. I am super disappointed in this Router. I expected much much more from Netgear but it seems like every router I own of thiers has issues with firmware updates that break other things.
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 8
Guru
Re: RAX80 Wired Ethernet Speeds are terrible
Did you ever try downgrading the firmware a version or 2?
And if you do change the firmware, make sure to do a factory reset with a clean install (not from a backup configuration).
I'd also advise any firmware changes be done over a hardwired connection.
What modem do you have?
Message 2 of 8
Scotty777
Tutor
I'm not entirely sure how to downgrade the firmware, maybe I can find that on here somewhere. I've done all firmware updates via a wired connection (That I recall anyway, I prefer to use my computer for most things vice phone apps.) If I do not have the older version of the firmware saved locally is an easy way to obtain the older versions?
The router is a NETGEAR Nighthawk 8-Sream AX8 WiFi6 Router. AX6000
Message 3 of 8
Guru
You can download it from the support site. Click on downloads, then view previous versions.
https://www.netgear.com/support/product/rax80.aspx
to install it, just follow the manual firmware update  process but use the older firmware and not the newer version.
I'd recommend doing so over a hardwired connection and factory resetting afterwards.
Message 4 of 8
Scotty777
Tutor
Thank you for the input! I will have to wait until I have a good window to try and go back (work and kid's school at home right now). Hopefully going back a couple versions will help. I will update
Message 5 of 8
Scotty777
Tutor
Dropped back a couple firmware versions and performed a factory reset, no joy, router ethernet connections (I tried them all) are still throttled way back when compared to the wireless connections. I'm going to buy a new cable and try that I suppose. Although I've never experienced an ethernet cable to go "partially" bad.
Message 6 of 8
Guru
I've had a cable go partially bad but it dropped if from 1gig to 100mbps.
Its worth a shot though.
Message 7 of 8
Scotty777
Tutor
Unfortunately, it looks like it’s the router. I tried 2 different cables, 2 different laptops, moving to all the ethernet ports, with similar results. Too bad, I really like this router (Wirelessly) but I require a reliable wired connection as well.
Message 8 of 8
Discussion stats
  • 7 replies
  • 1056 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
